OctaneRender™ for Blender 2022.1 - 27.5 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+/Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to Blender 3.3.1
  • Supported the new Curves system in Blender 3.3.1
  • Upgraded to Octane2022.1
  • Upgraded all shader nodes to the new addon style (with the quick-add feature and link validity checker)
  • Implemented the addon-style LiveDB feature
  • Implemented the addon-style OSL nodes
  • Implemented the addon-style RGB/Float/Alpha image nodes
  • Implemented the addon-style image tile node
  • Implemented the addon-style ramp node(Gradient, Volume gradient, Toon ramp)
  • Implemented the addon-style object data node
  • Implemented the addon-style camera data node
  • Implemented a fallback feature to use the old image and ramp nodes(Preferences-Octane-Experience the New Image and Ramp Nodes)
  • Implemented a node converter to convert the old shader nodes to the new addon nodes automatically(File-Export-OctaneBlenderAddon)
  • Supported using the node graph for the Kernels
  • Supported using "$VIEW_LAYER$" to control the view layer names in the exported file names
  • Added the Object Data Node in the Transform list
  • Used the new addon-style nodes when converting Cycles materials
  • Added "NetRender Preferences" option in the OctaneServer's right-click menu on the Windows
FIXES SINCE LAST RELEASE
  • Fixed the light crash
  • Fixed the scatter update issue when entering/exiting edit mode
  • Fixed the group asset import issue
  • Fixed some linking errors when inserting a node onto the existing link
  • Bug fixes
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.5 (3.3.1)
Octane Server - Enterprise Edition - 27.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
linograndiotoy
VERY IMPORTANT NOTE:
This version is marked as "stable". And it is, as long as new scenes are created using it. But please be aware that old scenes may present issues, since all nodes have been updated to be compatible with the upcoming Addon version.
My advice, as always, is to keep old versions you used to make important projects.
Please report any case where you may find nodes created in previous versions not working properly in this one.
That's a quite important transition moment.
Thanks!
