Anybody knows how to find key of EmberGenFX
WanwanTu
Greyscalegorilla,KitBash,is ok.But I couldn't find how to find the key of EmberGen.If someone knows,please help me.THank U very much
There is no key.
Please download EmberGen Win beta from here:
https://render.otoy.com/account/downloads.php?#core
Then use your OTOY credentials to activate it.
Happy GPU rendering!
ciao,
Beppe
navalguijo
Hello there.
I need to use the updated Embergen to import properly an alembic file as it is not working in the beta.
The actual version I found 1.0-QA6 in the Embergen Discord and it uses the new License management system which requires a key instead of the old otoy account licensing method
The Otoy web says:
"EmberGenFX: Full commercial license to 1.0 version included through 2023 subscriptions (More info)"
And I expected to be using this for a job today. Can I please get support on this?
frankmci
navalguijo wrote:Hello there.
The Otoy web says:
As I understand it, and from what JangaFX has posted on Youtube, Embergen 1.0 will be released next Wednesday. I doubt there will be an update to the Otoy licensed download version until at least then. Have you tried using the email address you use with Otoy to ask for the Licenses User Tag from the Janga Discord bot? I don't know if that will work or not, but it's worth a shot.
https://www.youtube.com/watch?v=R10whxb7MlU
Also, this from the Octane section of the Embergen Discord:
Boldalt — 02/28/2023 5:25 AM
Will users who are licensed through Octane/Otoy be able to download Embergen 1.0 once it has released?
Nick Seavert — 02/28/2023 12:14 PM
Yes and at this time you'll only have access until end of year and no additional updates past 1.0 (edited)
March 4, 2023
navalguijo
thanx @frankmci I have downloaded the 1.0 from the embergen discord
I also tried the 0.8 and I have the same issue, when I load Embergen no longer asks for my Otoy account as it happened with 0.7.5.8 version
My issue here is that the 0.7.5.8 reads my alembic file incorrectly with a different framerate (my original file is 30fps and Embergen beta reads it as 24fps and there's no way to set it up)
in Embergen 1.0 you can setup the framerate of the alembic inside embergen...
jasonpatnode
Try this.
1. Open the Beta version 0.7.5.8.
2. When that opens click the Update button.
3. This will update the beta to 1.01 but whenever you do open the program, it will ask for your Otoy login.
4. Open from the beta folder.
Downloading Embergen directly from JangaFK seems to not link to your Otoy acount. Doing the above looks to work.
orborneee
did you solve the problem, i want to know how to fix it.
Guillera
You may see the shortcut key for a button by moving your cursor over it if you can't remember it geometry dash meltdown Alternatively, choose Settings > Preferences > Shortcuts.
sharkvisual
WanwanTu wrote:Greyscalegorilla,KitBash,is ok.But I couldn't find how to find the key of EmberGen.If someone knows,please help me.THank U very much
I also have the same question.
