Cinema4D version 2022.1-RC3 24.11.2022
Hi all,
This is the latest experimental plugin build based on relese candicate 2022.1-RC_3 SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching Standalone 2022.1 RC 3.
While we're getting closer to a stable release, we advise to not use this release for production purposes yet.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
2022.1-RC3 plugin revisions
  • Better auto setup for Pyro objects
  • Fix: some internal errors with Octane ColorGUI and node storage
  • Fix: missing parameter in Comparison node
  • Fix: missing node inputs for Instance highlight texture
  • Fix: broken tiling of UVtag in stacked materials
  • Added the missing parameter in mediums: "single scatter amount".
  • New link parameter in Octane transform node. You can read transform matrix of any object with this option.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-26/R2023)
https://render.otoy.com/customerdownloa ... _3_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-26/R2023)
WINDOWS DEMO BUILD (R15-26/R2023)
Mac OSX Prime BUILD (R25-R26/R2023)
https://render.otoy.com/plugindownloads ... C3_OSX.zip
Please note the macOS build below will only work correctly on macOS 12.3.1 and newer, and only on Apple Silicon.
Also node previews are working with new style. Switch to old style and use from Node editor menu until we fix it.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
moebius
are there, or will be AOV passes for fire and smoke?
right now, cryptomatte does not work fine, but I dont know if it's possible...
SSmolak
If we have custom viewport panel organization ( for example perspective view on the top right side and top view on top left side ) adding camera cause that we have two top views - perspective is going to be top view.
camera_persp_to_top.zip
(87.48 KiB) Downloaded 319 times
Raoul
Quick question.. just reading the features announcement for octane 2023..
says this:
"Headless Metal and CUDA network render interoperability"
I've been waiting a while to figure out a hardware pathway forward.
Want to work on mac but render with cuda on PC slave using network render (ie not package up ORBX etc)
Is that now achievable? if so, hooray!
but would ask any caveats, limitations i should be aware of?
ta
R
Hi Raoul,
yes, Headless rendering is one of the new features of upcoming 2023 test version, but 2023 closed beta testing is going to start next month... stay tuned!
ciao,
Beppe
g5cedric
Hello,
will there be a version for no Silicon macs?
What is the future of Mac Pro 2019 intel xeon with octane?
thx
cedric
Cedric Uebersax, Photographer at France | http://www.cedric-u.com |
- Win11 ProArt X670E Creator 1x RTX 4090
- Win10 1909-Asus X-99 2x RTX 3090
- MacPro 7,1 Pro Vega II Duo
C4D R2023 / 2021.1.6
Hi cedric,
unfortunately AMD is not stable with new SDK, while Apple Silicon M1/M2 is rock solid now.
The devs are investigating the possibility to use AMD GPUs via Headless Rendering in 2023.1 SDK, to use them like eGPUs... fingers crosses!
ciao,
Beppe
rgbjoy
c4dOctane-R2023.xlib” can’t be opened because Apple cannot check it for malicious software.
How do I get this working?
You need to allow the c4doctane plugin and library in System Preferences/Security and Privacy panel, and restart C4D a couple of times:
After installation, you need to go to c4doctane Setting/Nodes, and disable the New style option, or material preview doesn't work in node editor:
ciao,
Beppe
rgbjoy
Thanks Beppe!
Two bugs I found:
If you add a spline with an ObjectTag to a cloner the hair tab disappears
also the hair with 1/1 thickness on any spline doesn't seem to be calculating correctly:
2022.1-RC3
