Delete unused materials, crash every time
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
boxfx
100% reproducible
Open attached project
Open octane texture manager
Use the c4d material manager's "remove unused materials" command
Crash every single time. Only crashes if the octane texture manager window is open.
c4d 26.107
octane 2021.1.6 R7
geforce 3090
MAT CRASH.zip
(2.53 MiB) Downloaded 121 times
You can change title as "Crash on Octane Texture manager" with this command. You can disable "auto update" until we fix it.
nullbio
I'm getting the same issue, but it's when deleting unused materials in the Octane node editor using the del key after highlighting the node. In particular on noises at the moment. What "auto update" are you referring to, so that I can stop the crashing?
Return to “Bug Reports”
