Cinema4D version 2022.1-RC2 19.11.2022
Hi all,
This is the latest experimental plugin build based on relese candicate 2022.1-RC_2 SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching Standalone 2022.1 RC 2.
While we're getting closer to a stable release, we advise to not use this release for production purposes yet.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
2022.1-RC2 plugin revisions
  • Cinema4D 2023.1 new Pyro feature support. You can activate rendering by just adding Octane Object tag to Pyro object. Add it after the visual effect calculated for a few frames. This will let the Octane detect the generated volumes and make the proper setup for you.
  • Fix: black textures when 'Faster previews' are enabled
  • Fix: a freeze case in node previews while animation rendering is in progress
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-26/R2023)
https://render.otoy.com/customerdownloa ... _2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-26/R2023)
WINDOWS DEMO BUILD (R15-26/R2023)
Mac OSX Prime BUILD (R25-R26/R2023)
https://render.otoy.com/plugindownloads ... C2_OSX.zip
Please note the macOS build below will only work correctly on macOS 12.3.1 and newer, and only on Apple Silicon.
Also node previews are working with new style. Switch to old style and use from Node editor menu until we fix it.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
m2001
Great update. thx aoktar for the seamless pyro integration incl. auto-setup!
Tipp:
To edit the volume parameter, click the node button on the Octane Object Tag.
SSmolak
Octane constantly update in attached scene - this is caused by displacer and spline field.
Pyro stopped to work if we using C4D perspective view.
oct_constantly_update.zip
(127.21 KiB) Downloaded 240 times
SSmolak wrote:Octane constantly update in attached scene - this is caused by displacer and spline field.
Have you tried that with other renderers? It's normal if any content is triggering update messages.
SSmolak
aoktar wrote: Have you tried that with other renderers? It's normal if any content is triggering update messages.
ok I found that this is Remesher issue. It constantly update mesh, even constrain to object tag doesn't work as should be - it updates C4D views and object is not sticking to surface but jumping.
EDIT : but it was my fault. I had spline inside remesher that works as field for displacer - removing this spline from Remesher hierarchy resolved this constantly viewport update :)
m2001
Bug?
Changes in Octane Environment Tag (with a HDRI Image) e.g. Parameter RotX & RotY doesn't update the octane live viewer.
I have to reload the full scene in live viewer, to see changes.
But, e.g. the Parameter "Power" updates the live viewer immediately.
Cinema 4D 2023.1
SSmolak
m2001 wrote:Bug?
Cinema 4D 2023.1
Works fine. Probably you have additional node between image texture and environment tag.
ceen
Quick info: You need to add "temperature" tag to temperature channel for fire rendering in Octane
3080ti
SSmolak wrote:
m2001 wrote:Bug?
Cinema 4D 2023.1
Yes, plugin cannot modify the complex internal structures for you. You have to translate the images by hand in these cases
boxfx
The c4d displacer is terrible for refreshing c4d scenes when nothing has changed. Even with a static displacement, pressing play causes it to endlessly recalculate your mesh and slow playback to a crawl, avoid them whenever possible.
