Bad Magic Number after Reinstalling Poser 11
ajr0717
Reinstalled poser 11 on a new PC after a very, very long time of using octane without needing to provide credentials, totally forgot what i did to get octane to work, ive installed stand alone, poser plugin, ive made sure im installing to poser.exe directory, but i don't think maybe i have the right download for poser 11. is there any version specifically for old poser 11? and by the way, props for decades old service, face off.
ajr0717
Hi. As per viewtopic.php?f=45&t=80572 the plugin only runs on Poser 12. If you have Poser 11, you would need to go back to the plugin version at viewtopic.php?f=45&t=73536.
ajr0717
I am being presented the error Could not find the required License or your subscription has expired.
If you already have a subscription to Octane Standalone and this plugin, release it by closing all instances of Octane Standalone and your plugin's host application elsewhere. You can also unlock any subscriptions in use on OTOY.com via My Account Subscriptions Page and Retry.
The following license subscription is required but was not available from your account (ajr0717)
ctane Render Studio Standalone
A license is available, however it does not have a valid all-access subscription.
0/1 license in-use.
[STAND -SUB-T2, 8124213) Requires all-access subscription) (LIC-T3/SUB-T3)]
-2022-11-18 13:45:14 UTC --
spartan00j
ajr0717 wrote:I am being presented the error Could not find the required License or your subscription has expired.
0/1 license in-use.
I think I know the issue. The license was attached to your old computer.
So you have to release the license or as it's called unlock the license.
You get a limited number of unlocks. You access it through your otoy account.
Go to either the license section or the subscription sections in your otoy account.
And look for the unlock settings.
Once you unlock your license. Sign in through the standalone and plug in.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
May I suggest if you cannot get this working, open a ticket with OTOY via the Support menu above. Please let them know the Octane version for the plugin you are installing.
ajr0717
installed octane 4 and it worked.... weird
Return to “Poser”
