OctaneRender for Maya 2022.1rc1-21.12 [OBSOLETE]
Locked
Forum rules:
NOTE: The software in this forum thread is not 100% reliable, this is a development build and is meant for testing by experienced octane users. If you are a new octane user, we recommend to use the current stable release.
!!! THIS IS THE BETA VERSION OF OctaneRender PLUGIN, IT IS RELEASED FOR INITIAL BUG HUNTING ONLY !!!
!!! PLEASE DON'T USE IT FOR PRODUCTION & DON'T SAVE THE SCENES FROM THIS BETA VERSION FOR FUTURE USE AS THERE ARE HIGH CHANCES TO LOSE THEM !!!
!!! SCENES SAVED IN THIS BETA VERSION ARE NOT GUARANTEED TO WORK IN SUBSEQUENT VERSIONS !!!
!!! THE RENDER ENGINE IS YET TO BE STABLE, SOME CRASHES & BUGS ARE EXPECTED FOR THIS TEST VERSION OF THE PLUGIN !!!
Otoy® is proud to announce the availability of a new test version of OctaneRender™ for Maya®: OctaneRender™ 2022
Maya® Version Requirements
This release will work with Maya® Versions 2018, 2019, 2020, 2022 and 2023 64-bit on Windows, Linux and macOS operating systems.
Changelog and the installers for Octane Standalone 2022 are here:
OctaneRender Standalone 2022
Changes since 21.11:
  • Integrated the 2022.1 RC1 engine.
  • Fixes and improvements...
NOTE: If you plan to use this plugin in Maya prior to 2023, DON'T UPDATE the Bifrost version from 2.4 installed by a Maya installer to 2.5! The Bifrost 2.5 SDK/API is completely incompatible with previous one, thus you will not be able to load this plugin.
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
Prime Downloads
OctaneRender for Maya Prime [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
ruhi
Hey Jim. Can you explain how to use bifrost with octane?
BK
ruhi wrote:Hey Jim. Can you explain how to use bifrost with octane?
Hi Ruhi,
Thanks so much for the post.
We are still investigating to support Bifrost 2.5.
For now, the workflow is to write out as VDB and reimport it.
cheers
Kind Regards
bk3d
ruhi
How about bifrost 2.4? i think this release should be support older version of bifröst
AdrienG
Hii
On macOS, unable to load octane plugin, i have this error in maya :
// Error: file: /Applications/Autodesk/maya2023/Maya.app/Contents/scripts/others/pluginWin.mel line 316: dlopen(/Applications/Autodesk/otoy/ofm_prime/2023/plug-ins/OctanePlugin.bundle, 0x0001): Library not loaded: @rpath/libbifrostapi_2_1_0.dylib Referenced from: /Applications/Autodesk/otoy/ofm_prime/2023/plug-ins/OctanePlugin.bundle Reason: tried: '/Applications/Autodesk/maya2023/Maya.app/Contents/MacOS/libbifrostapi_2_1_0.dylib' (no such file), '/Applications/Autodesk/maya2023/Maya.app/Contents/MacOS/libbifrostapi_2_1_0.dylib' (no such file), '/usr/local/lib/libbifrostapi_2_1_0.dylib' (no such file), '/usr/lib/libbifrostapi_2_1_0.dylib' (no such file) (OctanePlugin)
anyclue ?
thanks in advance for any help
BK
AdrienG wrote:Hii
anyclue ?
Hi AdrienG,
Thank you so much for reporting the error log.
Would you please confirm if you Bifrost installed?
We need Bifrost and Xgen to be installed to load OctaneRender for Maya plugin to load even though we do not use them!
Cheers
Kind Regards
bk3d
sirenesoong
HI,
I have problems with Maya 2023:
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/others/pluginWin.mel line 316: Impossibile trovare il modulo specificato.(OctanePlugin)
thanks for any help
Gianmarco
Q6600, 8 GB ram, Geforce480
BK
sirenesoong wrote:HI,
thanks for any help
Gianmarco
Hi Gianmarco,
Thank you so much for the post.
Would you please make sure if Autodesk Bifrost and Xgen are installed?
cheers
Kind Regards
bk3d
Locked
