Doesn't start at all...
Discussion forum for Sculptron
MyRho
I've installed several versions of scultron several times but without any success.
I'm using a enterprise license for octane; WC and Embergen are running fine but whenever I try to start Sculptron nothing happens at all.
Do I need a special license to run it?
MSI MPG Infinite X2 MSI GeForce RTX 4090 24 GB VENTUS Intel i9 14900KF
Nihil sum sine sole.
bbuxton_1
Doesn't work here either.
Just out of interest are you using a non AVX compatible CPU? My first thought was that might be why it is not running on my ancient 2012 MacPro (Windows 10)
Architron is compiled for an AVX system, even though it does not use AVX. I could not persuade Victor to recompile it with Maxon's non-AVX compiler and the AVX flags set to off. So I stopped using it (Paid license from LWCad).
Still works on Lightwave though.
MyRho
My computer has an AVX compatible CPU - but I still can't get sculptron to run.
Tried everything, disabled firewall/AV, made all the windoes (10 PRO) updates, updated all drivers, tried all the options like win8-mode and so on...
started in administrator mode...
nothing.
I don't know any more options no w - so I need some hepl with that.
Thank you.
Return to “Sculptron”
