Cryptomatte / AOVs questions - help
Pavlov
Hi all,
in Octane for Lw the only Cryptomatte channel that seems to work is material pin node. Other ones are unreliable or create too many photoshop layers.
Questions are:
1 - is there a pratical way to *group* materials or objects so i get less crypto layers ? I.e. if i have an instanced grass i would love to get a single mask out of it, not 30 masks for each single material in the ecosystem.
2 - Putting Cryptomatte aside, in Corona for MAX i can select the BW masks to output and even group objects together. Is there a pratical way to chose which object should go in each mask using other techniques which are not cryptomatte (layers, baking groups, etc) ? BTW the default Object ID and Material ID masks are useless since the selection is not precise at all.
Thanks in advance,
Paolo
I7 960 3.2 GHZ - 6GB ram - GTS 250 display only - Asus GTX 470
Return to “Lightwave 3D”
