Cinema4D version 2022.1-XB4-(R2) (Experimental) 18.10.22
Hi all,
This is the latest experimental plugin build based on experimental 2022.1-XB4 SDK. Any feedback will be much appreciated. Enjoy it!
This is the SDK matching OctaneRender® 2022.1 XB 4.
As with all experimental builds, we advise to not use this release for production purposes. We are trying to, but we can't guarantee that scenes saved with this version will be compatible in future releases. Please note that because of the active development, there are several limitations outlined below.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
2022.1-XB4-(R2) plugin revisions
  • Fix the delay "faster material previews" option
  • Layer support on Material Convert command
2022.1-XB4 plugin revisions
  • Improved viewport texture performance. New caching and threaded method is activated for faster creation/storing for scene loading and material editing. You can change it by "Faster viewport textures" in settings/other panel.
  • Removed: OLD_VOLUME_BEHAVIOR/USE_OLD_COLOR_PIPELINE from kernels
  • Removed: MAX_UPSAMPLING_INTERVAL from camera imagers
  • Added "use groups" parameter to Object tag for enable/disable the xpEmitter+groups usage
  • New texture nodes
  • New compatibility modes on some nodes. See standalone topic for details
And lot of fixes/addons from the core. See standalone topic for details.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-26/R2023)
https://render.otoy.com/customerdownloa ... R2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-26/R2023)
macOS 12.3.1(M1 cpu) BUILD (R25-R26/R2023)
https://render.otoy.com/plugindownloads ... R3_OSX.zip
Please note the macOS build below will only work correctly on macOS 12.3.1 and newer, and only on Apple Silicon.
Also node previews are working with new style. Switch to old style and use from Node editor menu until we fix it.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
SSmolak
Insane, thank you very much !
eyeonestudio
Thank You~ XB4
Overlapped Sub Button.
pxlntwrk
Just for information, when I reopen a project on which I have already worked previously with "Faster viewport texture" activated, all my materials appear black in the viewport. fast but black!
Even if I create a new scene the materials still appear black in the viewport.
The function seems to work correctly only with freshly created scenes.
pxlntwrk.net
pxlntwrk wrote:Hi,
It's not like that but thanks! Black is happening sometimes not consistent, checking it!
pxlntwrk
aoktar wrote:
pxlntwrk wrote:Hi,
With this version I also have more software closings than usual.
Here are attached, some bugreports from this beginning of the day.
bugreports_20221017.zip
(20.01 KiB) Downloaded 269 times
pxlntwrk.net
pxlntwrk wrote:
aoktar wrote:
pxlntwrk wrote:Hi,
Not sure what you mean but disable "Faster viewport texture" if you say you have crashes. There is nothing to cause this in plugin side else of that. Could you please explain what are we talking about?
SSmolak wrote:Insane, thank you very much !
Did it work well on you?
eyeonestudio wrote:Thank You~ XB4
Updated the links with a fixed build.
eyeonestudio
Perfect~~ :) Thank You.
hugesplash
There's no download link for "macOS 12.3.1(M1 cpu) BUILD (R25-R26/R2023)"… :(
