OctaneRender™ for Blender 2022.1.XB4 - 27.4 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Integrated Octane 2022.1.XB4
  • Added quite a few new nodes which are introduced in Octane 2022.1.XB4
  • Re-layout the camera imager and post-processing panel
FIXES SINCE LAST RELEASE
  • Fixed the crash when exporting scenes without cameras
  • Various bug fixes
You can read about new features of OctaneRender™ 2022.1.XB4 here:
viewtopic.php?f=33&t=80512
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.4 (3.3)
Octane Server - Enterprise Edition - 27.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
azen
Hello,
In addition to the Windows and Linux builds, here are a the download links for the Octane X version of this current Test Build. As with the other downloads, this build is not considered suitable for Production work.
This is an Octane X version, so this will not run on any of the older macOS machines that still use CUDA based GPUs.
macOS 12.3.1 (M1 CPU)
Octane Server - 27.4
