Render To Disk
Hydra Solaris
stevepickup
Hello - Just doing some intial testing with Octane in Solris. I'm coming up against a problem rending to disk using the 'Octane' node.
If I render usin the 'rendersettings' followed by the 'USDRender_ROP' node and set to use Octane as the delegate all is okay.
But i'm guessing the workflow should now be to use the 'Octane' node?? but for some reason when you hit the 'render to disk' button, absolutly nothing happens. Any idea what im doing wrong?
BK
stevepickup wrote:Hello - Just doing some intial testing with Octane in Solris. I'm coming up against a problem rending to disk using the 'Octane' node.
Hi Steve,
Thanks so much for the post.
Yep, we could use both USD ROP attached to rendersettings node or Octane node to render the images.
For Octane output, please try entering the image output path in the **Output Picture** parameter instead of the USD override path.
Please let us know how it goes!
Cheers
Kind Regards
bk3d
Return to “Hydra Solaris”
