Compatibility issues between octane and unreal materials
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
banandai
Problems with convertation Octane material from orbx scene to Unreal 4.27
1. If the texture passes through Color correction node then it will not be imported into Unreal material
2. Texture emission node assign as normal, Roughness as Specular, Opscity as refraction, Normal as Opacity.
3. Most of the normal map is imported as a non-srgb image.
Currently scripts from users work better than orbx converter in unreal.
Example:
Orbx import
Сonversion of materials using a script viewtopic.php?f=88&t=58420, after imported in fbx format
ChrisHekman
This is now fixed and will be part of the next build.
This was an issue with universal materials, and should be fixed in the next build.
Ill take a look at this.
Return to “Unreal® Engine”
