OctaneRender™ for Blender 2021.1.6 - 26.5 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to Blender 3.3
FIXES SINCE LAST RELEASE
  • Fixed the empty image crash
  • Fixed the mesh data update issue under edit mode
  • Fixed the hanging issue for some old scenes
  • Fixed the rendering issue when editing UV on the fly
  • Fixed the "endless" refreshing issue for the metaballs and vertex displacement
You can read about new features of OctaneRender™ 2021.1.6 here:
viewtopic.php?f=24&t=80315
1. OctaneRender™ Server
Windows
Blender Octane Edition - 26.5 (3.3)
Octane Server - Enterprise Edition - 26.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 26.5 (3.3) Linux
Octane Server - Enterprise Edition - 26.5 Linux
