Cryptomatte changing colors
RyanScammell
Hi there,
I had this issue the other day where a cryptomatte we rendered out was changing colors midway through the render. Give the EXRs in this file a look:
https://www.dropbox.com/sh/kry1ch9hxq58 ... BLM3a?dl=0
What causes that change around frame 40? (I mentioned in another post the gamma of a rendering changing mid render). If the colors change the cryptomatte becomes kinda useless. Similarly to my other post this would have been a single project with a single set of settings placed in the render queue. The render may have crashed a few times and had to be restarted. But we always would have just restarted the render via the Cinema 4D render queue without changing any settings. We are net-rendering between multiple machines so it's possible something's related to that? Running octane via Cinema 4d on Windows. This would have been with octane 2021.1.5.
Let me know your thoughts.
-Ryan
Hi Ryan,
please make sure to use Cryptomatte MaterialNodeName, instead of simple MaterialNode, or the assignment will change every time you open the scene, or you add a new material.
ciao,
Beppe
moebius
and "Instance", if you wanne matte objects. I believ the rest is not working.
