Info Passes - Normal smooth & shading passes flipped
Longbongosolo
Seems like the naming of the Normal (smooth) and Normal (shading) passes is flipped when you view them in the passes dropdown menu. So, if you tick Normal (smooth) you actually get Normal (shading) and vice versa.
Screenshot of flipped naming of the Normal (smooth) and Normal (shading) passes
You are right. This will be fixed in the next release.
Return to “Foundry Modo”
