OctaneRender™ for Blender 2022.1.XB3 - 27.3 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Blender 3.3
  • Added "color space" sockets to the tiled image, float image, and alpha image nodes
  • Supported the camera data node in the AOV node tree
  • Supported copying shader nodes to the octane AOV node tree
FIXES SINCE LAST RELEASE
  • Fixed mesh auto-smooth update issue under viewport rendering
  • Fixed "Scatter on surface/volume" node export issue
  • Fixed the mesh data update failure when exiting edit-mode
  • Fixed the update failure when changing the interpolation mode of the gradient nodes
  • Fixed the issue when unregistering the interface classes
  • Fixed the issue of clearing the create_node method
  • Fixed the crash due to empty images
You can read about new features of OctaneRender™ 2022.1.XB3 here:
viewtopic.php?f=33&t=80156
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.3 (3.3)
Octane Server - Enterprise Edition - 27.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
azen
Hello,
In addition to the Windows and Linux builds, here are a the download links for the Octane X version of this current Test Build. As with the other downloads, this build is not considered suitable for Production work.
This is an Octane X version, so this will not run on any of the older macOS machines that still use CUDA based GPUs.
macOS 12.3.1 (M1 CPU)
Octane Server - 27.3
