Octane 2021.1.6 for Unreal Engine - 0.57 Fixes
Moderator: ChrisHekman
ChrisHekman
Octane for Unreal Engine
Changes:
  • ORBX Importer: Emission booleans in unreal are now set to materials and components
  • ORBX Importer: Texture gamma an power are now converted in previz materials
  • ORBX Importer: Added model scaling for imported OBJ models
  • ORBX Importer: Scatter nodes with only 1 transform are now converted to StaticMeshComponent instead of InstancedMeshComponent
Fixes:
  • ORBX importer: Improved the material mapping on StaticMeshComponents and model assets based on OBJ models
  • Added alpha for UDIM/Virtual textures
  • Fixed issue where UDIM/Virtual textures could be loaded incorrectly due to gaps or inccorect block order
  • DBuffer material nodes now default to 0,0,0,1 + a warning instead of an error
  • ORBX proxies are now properly cleaned up when removed from the scene
  • Blueprint node name fixes
  • Blueprint functions cleanup and minor improvements
  • Added texture sample wrapping for UDIM/Virtual textures (only for 5.0)
  • Fixed possible crash with dynamic octane materials
  • Fixed ORBX import crash when no new level was created (either by user choice, or some other reason)
  • RaytracingSwitch and PathtracingSwitch material nodes now work correctly in octane
  • ORBX importer: Fixed crash when model is missing due to conversion issues
  • ORBX importer: Now cleans data up properly after itself
  • ORBX Importer: Fixed issue where alpha image is not used
  • ORBX Importer: Renamed "converted" to "previz" for converted unreal materials
  • ORBX Importer: Fixed issue where textures were not linked to rendertargets when they were not Texture2D textures
  • ORBX Importer: Fixed issue where rendertargets would not get their textures linked on grayscale image nodes.
UE 4.27
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_27.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_27.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_27.exe
UE 5.0
Studio Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... _UE5_0.exe
