how can i drive the uv to get Texture animation ?
1234fk
I can finish this by useing Texture effect set to Texture Offset.
But Octane can't take up it . is there some way to set that in Octane Setup viewport ?
Hi. I am away from the office for the next 8 days. I will look at this issue when I return.
1234fk wrote:I can finish this by useing Texture effect set to Texture Offset.
Hi. Sorry for the late reply. Unfortunately the plugin does not support the Texture Offset "Effect", so you will need to convert the material mask to an Octane Override and get the material to render as you want using the Octane nodes in the Modo schematic.
Return to “Foundry Modo”
