OctaneRender™ for Blender 2021.1.6 - 26.4 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to Blender 3.2.2
  • Upgraded to 2022.1.6
  • Supported dragging the new-created nodes as the Cycles
FIXES SINCE LAST RELEASE
  • Fixed the baking ID update issue
  • Fixed the mesh cache out-of-date issue when using edit-mode
  • Fixed the random color texture issue
  • Disabled the "Persistent Data" option for the octane scenes
  • Various Bug fixes
You can read about new features of OctaneRender™ 2021.1.6 here:
viewtopic.php?f=24&t=80315
1. OctaneRender™ Server
Windows
Blender Octane Edition - 26.4 (3.2.2)
Octane Server - Enterprise Edition - 26.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 26.4 (3.2.2) Linux
Octane Server - Enterprise Edition - 26.4 Linux
