Plane with shadow caster material applied isn't transparent
epilandrus
Here is the scene:
https://drive.google.com/file/d/1-94Bv2 ... sp=sharing
epilandrus wrote:Plane with shadow caster material applied isn't transparent
Here is the scene:
Sorry, didn't check the scene, but Shadow Catcher has some limitations, like not working well emitters, only Environment nodes.
Try to use the Render Layer technique instead, you can have also reflections, not only shadows on the plane:
https://docs.otoy.com/cinema4d/RenderLayer.html
ciao,
Beppe
