Takes trigger incorrect render kernal
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
boxfx
The attached project has 2 takes and 2 render settings. One take uses normal render settings (direct lighting kernal) and the other take uses some render settings with a kernel overwrite set to "info channels: Material ID"
When I select a take and press the usual "render to picture viewer" button, I get the correct lit render and material ID passes.
When I run the command "render marked takes to picture viewer", Instead I only get the material ID pass twice, the standard direct lighting kernel render is missing.
c4d 26.107
octane 2021.1.5
gf 3090, latest drivers
takes bug v1.zip
(58.83 KiB) Downloaded 91 times
boxfx
There is a workaround for anyone else that has this issue. Enable "overwrite kernel" for all render settings.
Return to “Bug Reports”
