OctaneRender™ for Blender 2022.1.XB3 - 27.2 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Blender 3.2.1
  • Upgraded to 2022.1.XB3
  • Added the "Curvature visibility" in the object property panel
  • Added the "Emission Weight" pin in the standard surface material
  • Disabled the "Persistent Data" option for the octane scenes
  • Supported dragging the new-created nodes as the Cycles
KNOWN ISSUES
  • Fixed the mesh cache out-of-date issue when using edit-mode
  • Fixed the random color texture issue
  • Fixed the traceback when changing the baking group ID of the camera
You can read about new features of OctaneRender™ 2022.1.XB3 here:
viewtopic.php?f=33&t=80156
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.2 (3.2.1)
Octane Server - Enterprise Edition - 27.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
azen
Hello,
In addition to the Windows and Linux builds, here are a the download links for the Octane X version of this current Test Build. As with the other downloads, this build is not considered suitable for Production work.
This is an Octane X version, so this will not run on any of the older macOS machines that still use CUDA based GPUs.
macOS 12.3.1 (M1 CPU)
Octane Server - 27.2
