Baking from HighPoly
seriawp
:roll: Hello juanjgon! I need couple very important thing for me!
1. Baking texture direct to Lowpoly, but without using lowpoly itself. I prepared realy simple scene for example. Need bake this result, from hipoly render to lowPoly mesh camera. (maybe it's calling - camera mapping)
How to do it? is it possible to implement this?
It would be cool if we could also bake render passes like AO and Normal. But not necessarily!
Simple Scene for axample: https://drive.google.com/file/d/1q5-g-2 ... j-63rC6pxY
juanjgon
I'm not an expert in texture baking at all, but as far as I know, Octane can bake the current object shading and lighting to texture maps that later you could apply to any other object with the same UVs, even a low poly one. Not sure if this is what you are looking for, but this is how Octane works.
seriawp
juanjgon wrote:I'm not an expert in texture baking at all, but as far as I know, Octane can bake the current object shading and lighting to texture maps that later you could apply to any other object with the same UVs, even a low poly one. Not sure if this is what you are looking for, but this is how Octane works.
You're right, that's not what I meant.
Highpoly do not have UV, and it is necessary that shading and lighting from Highpoly bake to lowpoly UV in same position. :?
juanjgon
I think that Octane doesn't have this kind of tool. You need at least one UV map to bake the lighting and apply the textures to the lowpoly object.
Return to “User Requests”
