OctaneRender™ for Blender 2022.1.XB2 - 27.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, OSX (Metal), and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to the 2022.1.XB2
  • Upgraded to Blender 3.2.0
  • Supported quite a few new nodes in the 2022.1.XB2(PixelFlow, RainBump, Scratches, SnowEffect, CircleSpiral, FanSpiral...)
  • Supported the Octane Proxy Node in the Linux/OSX versions
  • Implemented Cryptomatte mask node and picker
KNOWN ISSUES
  • Fixed the wrong color issues when importing LiveDB materials
  • Fixed the outline color/thickness issue in the toon material
  • Fixed the light panel UI issue
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2021.1.XB2 here:
viewtopic.php?f=33&t=79999
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.1 (3.2.0)
Octane Server - Enterprise Edition - 27.1
OSX (Metal)
DOWNLOAD
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 27.1 (3.2.0) Linux
Octane Server - Enterprise Edition - 27.1 Linux
