Octane Scatter - on the inside surface of object
A forum for discussion, development and support, including subforums for discussion for various plugins for octane render and 3d the relevant animation packages
silanbekjarov
Hi Guys,
is there a possibility to use octane scatter in such way as to add the scatter to the inside surface of a closed object. Basically a container whose walls are covered with scatter objects on the inside and not on the outside, as it usually would be used. For example a Glas Cube with Bugs in it crawling the walls.
Appreciate any ideas.
Love,
Silan
jobigoud
You could try to put a transform on the instanced object so it's rotated 180° around the X or Z axes. Or add a rotation to instances. Or invert the normals of the host geometry.
Return to “Plugin Discussion/Support”
