denoise not working when using a camera crop
Houdini Integrated Plugin
heimlich
somehow, octanes denoise is not working when using the camera crop via the cropl/r/b/t parameters... is this a bug ?
juanjgon
I think that this is an Octane core limitation. The last time I checked it out, even Standalone had the same limitation.
jobigoud
It works for me in standalone 2021.1.4 and 2022.1.XB2. Denoised beauty pass with region start/size in film settings.
heimlich
Thanks for confirming that. There seems to be an issue where its not detecting that the frame is completed. If you turn off "denoise on completion" and set the max interval to 1.. you can force it and it then does indeed work here as well. Junajo is aware.
Return to “Houdini”
