ORBX Animation file export is not working
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
EyasArraf
Houdini 19.0.622
Octane for Houdini 2021.1.5.0
Hi, i'm trying to use Otoy's RNDR by exporting my animation scene to an ORBX file.
The ROP node is set to Render Frame Range and under the Archive tab the export mode is set to Full ORBX Scene.
But it only exports an alembic .abc file inside a directory called "basename assets" - with no ORBX file.
What to do?
P.S. It seems to work fine when exporting just one frame.
juanjgon
Can you please share the scene to take a look at it here? Perhaps the problem is that it is configured to be rendered in "Full scene reload" mode, something not supported by the .orbx animated scene export functions.
EyasArraf
juanjgon wrote:Can you please share the scene to take a look at it here? Perhaps the problem is that it is configured to be rendered in "Full scene reload" mode, something not supported by the .orbx animated scene export functions.
Sorry this is my first time posting. How do I share a file here?
juanjgon
Don't ask me why, but the problem is related to the frame range. If you render for example from frame 1 to 85, the scene export works fine! It must be some kind of glitch in the export code, but it seems that the workaround is to change the frame range.
EyasArraf
juanjgon wrote:Don't ask me why, but the problem is related to the frame range. If you render for example from frame 1 to 85, the scene export works fine! It must be some kind of glitch in the export code, but it seems that the workaround is to change the frame range.
That's right. I got that after some frame range trials.
Also trying to export the ORBX scene without initiating the Octane Live Viewer at least once in the Houdini session would result in exporting only an alembic file without ORBX.
After all I managed to export the scene as needed by changing the frame range.
Thanks anyway.
Return to “Bug Reports”
