OctaneRender™ for Blender 2022.1.XB1 - 27.0 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, OSX (Metal), and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to the 2022.1.XB1
  • Supported photon trace kernel
  • Added the "Allow Caustics" to the materials and layers
  • Replaced the old border mode with the new border mode UV in the image nodes
  • Added ACESToneMapping in the imager
  • Removed PremultipliedAlpha from the imager
  • Added PremultipliedAlpha in the export output setting
  • Added shader nodes: StandardSurfaceMaterial, StandardVolumeMedium
  • Added quite a few new nodes
KNOWN ISSUES
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2021.1.XB1 here:
viewtopic.php?f=33&t=79602
1. OctaneRender™ Server
Windows
Blender Octane Edition - 27.0 (3.1.2)
Octane Server - Enterprise Edition - 27.0
OSX (Metal)
DOWNLOAD
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 27.0 (3.1.2) Linux
Octane Server - Enterprise Edition - 27.0 Linux
