Hey! Can you please tell me if there is any way to transfer materials from cinema octane to Houdini octane? Maybe bake?
Ideally, make sure that the shader settings are preserved.
The fact is that we set up design, lighting and rendering in cinema, and the subsequent complex process, the project hierarchy and final rendering is done by a specialist in Houdini
Cinema 4D Octane to Houdini Octane
You can use the LocalDB feature to export materials from C4D and import them into Houdini. The material imported inside Houdini is a bit of a mess because all the nodes are expanded, even the constant values, but well, it should work and you can edit the parameters if you need to.
