About LV regions and compare mode interacation issues
Delizade
Hello,
I wanted to write down my personal issues about regions and comparing mode of LV:
1- after drawing a film/render region if user changes "rendering zoom factor" or
"viewing zoom factor" values ragion area should be focused on the visible area in the LV window.
Becasue after changing zoom factor, selected ragion area is disappearing from the vieweing area in the LV.
User has to pan or zoom out to find that area.
2) after drawing a film/render region if zoom factor is lowered comparing line can't be handled by the cursor (becomes harder to catch)
Comparing line should have static with or interaction area regardless of zoom value.
3) if a region is determined on the LV visible area if user enable compare function by clicking to "store render buffer",
comparing line should be placed over the selected region area not outside of the visible area of the LV.
4) Region rectangles should have control handles on the edges to let user make changes more easily.
5) If the user presses the "store render buffer" while the line is at the desired location,
the line's position is reset and go out from the current position. It should be stay wherever it was.
thank you
Return to “User requests”
