crash opening orbx material w/ render preview active
baxley
while having the ipr render active and opening orbx materials to edit I literally close my eyes and cross my fingers everytime i click 'edit orbx'.
Why hasn't this been fixed yet?
I've been complaining about it for over 2 years now.
Can't imagine I'm the only one having this problem.
Has been happening with maya 2020 and 2022
Running windows
3090
BK
baxley wrote:while having the ipr render active and opening orbx materials to edit I literally close my eyes and cross my fingers everytime i click 'edit orbx'.
Running windows
3090
Hi Baxley,
Thanks for the post.
we are unable to replicate this on our end.
Would you please share the scene file and the step to replicate this issue?
cheers
Kind Regards
bk3d
baxley
Shocked you haven't experienced this... if i have the live viewer running for a few minutes and open/close several orbx materials to edit... generally by the 6th material open I freeze/crash. Has been happening since maya 2018, 2019, 2020, 2022 and now 2023.
Is there a log somewhere I can find/send to you?
Cheers
BK
baxley wrote:Shocked you haven't experienced this... if i have the live viewer running for a few minutes and open/close several orbx materials to edit... generally by the 6th material open I freeze/crash. Has been happening since maya 2018, 2019, 2020, 2022 and now 2023.
Cheers
Hi Baxley,
It seems the crash might be related to something else and yes, we are still unable to reproduce Orbx material crash with the IPR active.
1. Please set the Textures resolution(px), Texture quality(ssp) and Swatch quality(ssp) to 1 from the RenderSetting dialog>Octane tab> Maya viewport default rollout.
2. Also, disable the Automatic swatch update in Hypershade if you are using it. Maya would enable the (click on-demand) to see the material update.
Usually, Maya would generate MayaCrashDump files if it crash under the C:\Users\YourUserName\AppData\Local\Temp folder.
To generate octane_log.txt, copy the octane_log_flags.txt from the zipped file
octane_log_flags.zip
(357 Bytes) Downloaded 175 times
inside lib folder in Program files\OctaneRender for Maya\lib path. The octane_log.txt file can be found in the same temp directory.
Looking forward to hearing back!!
Cheers
Kind Regards
bk3d
baxley
Looks like changing those settings stoped crashes while opening orbx files. Thank you.
Bummer those settings are default.
Currently when i click on the world map with daylight environment... where i click on the map is never where the cursor actually goes. I also can't click/drag on the map to get the perfect setting like I can in standalone.
Is there some settings I can chance to fix this?
Thank you!
baxley
Also, when rendering an image a tab briefly appears with the render aov's , other octane settings. However it disappears immediately and I can't seem to get it to stay visible to actually use it... any way I can fix this?
Thanks again!
BK
baxley wrote:Looks like changing those settings stoped crashes while opening orbx files. Thank you.
Thank you!
Hi Baxley,
We are glad to know Maya stopped crashing after changing the above settings. Maybe it's related to our swatch preview generator.
The World map with daylight environment issue will take some time for us to investigate.
As a workaround, please use Calus' script from the link (viewtopic.php?p=356003#p356003)
Please note to create Environment>Daylight Environment and run the script or can save it in the Shelf using the MMB after highlighting the Mel script.
Cheers
Kind Regards
bk3d
BK
baxley wrote:Also, when rendering an image a tab briefly appears with the render aov's , other octane settings. However it disappears immediately and I can't seem to get it to stay visible to actually use it... any way I can fix this?
Thanks again!
Would you please share a screenshot or a video?
cheers
Kind Regards
bk3d
Return to “Autodesk Maya”
