Rendering fails on small sizes (112px x 112px)
GXGsynth
I'm trying to render out some really small images to make animated icons that need to be at 112px x 112px but every time I try to render at that low of a resolution, I get render failures, both in C4D and exported ORBX files, how can I solve this?
--------------------------- EXPORT LOG ---------------------------
Tried to access pin via an invalid ID P_SUB_TYPE (703)
Tried to access null node pin
can't read int/enum from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFE73820100)
Multi-threaded material conversion, thread count=14
Export materials time= 99.755 ms
Collect objects time= 2.155 ms
Mesh creation time = 4.7 ms.
Api update time: 2.911 ms.
VRAM used/free/max:1.143Gb/4.835Gb/8Gb Out-of-core used:0Kb RAM used:18.791Gb total:63.917Gb OpenGL free/total:0/0
FRAME:0 fps:30
Export materials time= 1.14 ms
Collect objects time= 0.056 ms
Mesh creation time = 2.244 ms.
MB:0/0 ST/MOV:0/1 Nodes:14 Tris:204 DispTris:0 Hairs:0 Meshes:1
Textures Grey8/16:0/0 Rgb32/64:3/0
VRAM used/free/max:1.258Gb/4.607Gb/8Gb Out-of-core used:0Kb RAM used:19.112Gb total:63.917Gb OpenGL free/total:0/0
denoiserThread0: CUDA_ERROR_ILLEGAL_ADDRESS: an illegal memory access was encountered. Restart required
CUDA error 700 on device 0: an illegal memory access was encountered
-> failed to deallocate device memory
-> could not get memory info
denoiserThread0 : Exited with a error. Restart required
Check geometry subdivisons.
Picture viewer uses 'Render' subdivisions. But Live Viewer uses 'Editor' subdivision values.
Try to decrease 'render/editor' subdivison values.
-> failed to destroy CUDA event
-> failed to deallocate pinned memory
-> failed to destroy texture objects
-> failed to deallocate device array
-> failed to unload module
OptiX error for device 0: [ERROR] Error synching on OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
Error destroying OptixPipeline event (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
OptiX API error for device 0: CUDA error
OptiX error for device 0: [ERROR] Failed to destroy launch resources (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
Error de-initializing device (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
could not request a tonemap because we don't have any renderthreads available.
Break rendering...
**** RENDER FINISHED **** stat=6
CUDA error 700 shouldn't be related to the specific scene, but to corrupted or wrongly installed Nvidia driver :roll:
Please write to help at otoy dot com, sharing a link to this discussion, so we can investigate more deeply.
ciao,
Beppe
