OctaneRender™ for Blender 2021.1.4 - 26.2 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Set the Vignetting to 0 by default to match the Standalone
  • Used the "new" nodes in the LiveDB as much as possible
FIXES SINCE LAST RELEASE
  • Fixed the modified mesh data out-of-sync issue
  • Fixed the mesh data out-of-sync issue under the edit mode
  • Fixed the animation render issue when the Cycles' "Persistent Data" feature is on
  • Fixed the "Quick-Add" feature for the Toon Ramp textures
  • Fixed "VR Scene Inspector" addon traceback
You can read about new features of OctaneRender™ 2021.1.4 here:
viewtopic.php?f=24&t=79488
1. OctaneRender™ Server
Windows
Blender Octane Edition - 26.2 (3.1.2)
Octane Server - Enterprise Edition - 26.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 26.2 (3.1.2) Linux
Octane Server - Enterprise Edition - 26.2 Linux
