Both in Houdini and C4D:
if you pipe IMAGE > Color Correction > Displacement , it breaks displacement. Mesh flattens. Same happens if you pipe IMAGE > ToolRange > Displacement.
How so? How would you otherwise adjust white and black values of the image to influence displacement?
2021.1.4.2 - color correction breaks displacement
C. RAM Capacity (i.e. 6 GB)
The conventional displacement node is only compatible with the texture image node over UV mapped objects. No other shader node or projection can be used. If you need to build a node tree for displacement you need to use the new vertex displacement node.
