Issue with stage object / switching cameras
jessestormer
I'm having an issue with using the stage object and switching between cameras -- Octane won't complete rendering/saving a frame on the frame immediately after a camera change. (just one frame immediately after the camera change)
I would say it is 'crashing' but it doesn't exactly error out or quit, it just doesn't complete.
I can of course work around this for now by rendering each of those frames manually, but this does seem like something is a bit screwy.
Nothing is being flagged in the console, it just hangs.
Thank you for any ideas you may have on how to remedy this, and be able to render straight through a sequence.
Weird, try to check that both C4D Project and Render Settings have the same FPS :roll:
ciao,
Beppe
