OctaneRender™ for Blender 2021.1.4 - 26.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to the Blender 3.1.2
FIXES SINCE LAST RELEASE
  • Fixed the Denoiser render issue in the final render mode
  • Fixed the crash when using Cycles
  • Various Bug fixes
You can read about new features of OctaneRender™ 2021.1.4 here:
viewtopic.php?f=24&t=79488
1. OctaneRender™ Server
Windows
Blender Octane Edition - 26.1 (3.1.2)
Octane Server - Enterprise Edition - 26.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 26.1 (3.1.2) Linux
Octane Server - Enterprise Edition - 26.1 Linux
