Render more Jobs of one Scene
Discussion forum for OctaneRender Cloud
Enermed
I like to render more Jobs from one scene and don't know how?
Do I have to upload 5 times, to be able to render 5 still images with 5 camera positions?
I use Octane X c4d with Mac M1 Max and it also don't work that the file automatically upload if I go to send file.
I need o upload it on the website directly.
Do I need to install there any other thing or is it just not woking with my configuration?
thanks a lot for your help!
you need to edit the .orbx scene in Standalone, in order to create five Render-Target nodes, each one connected to a different Camera.
When the .orbx scene is loaded in RNDR, you can choose which render target to render, and prepare five differnt jobs from the same scene.
To export your Cameras from c4d to Standalone, use the C4D Alembic Exporter to export only the selected Cameras, import in Standalone and change the node scale from Meters to Centimeters, then use the following lua script to convert the abc Camera pin into a Thin Lens Camera node:
viewtopic.php?f=73&t=49960#p247491
ciao,
Beppe
Return to “OctaneRender Cloud”
