GPU scaling across render nodes
adrencg
I have a workstation with 3 x 3070. I get about 3 minutes per frame with a scene I'm currently working on.
When I add 3 render nodes with a similar hardware setup, the render time is only reduced by 50%. Should I get a much faster render when adding 3 more nodes?
Ryzen 5950x
128GB Ram
RTX 3070 x 3
Which type of network connection do you have between Workstation and render-Nodes?
Probably you are losing time is sending receiving data from render-Nodes during net render :roll:
ciao,
Beppe
