Optimize Nvidia GPU Settings
eyelovemotion
Hey guys,
i am wondering if there are settings in the Nvidia driver/Control Panel which can be optimized for 3D/ Cuda rendering.
In the settings of the Nvidia Control Panel all values are set to automatic/ standard ect.
Does anyone have suggestions on that?
Cheers
glimpse
there is no need to touch those as they would not change a thing for OctaneRender.
The best You can do is to provide enough airflow, to remove head properly. Of You have headroom for temp You can try to increase core/mem speed, lift power target, adjust fan speed. However if You airflow is not enough, You might get the opposite effect where You would reach thermal throttling faster, causing not only lower render speed but also possible instabilities.
