OctaneRender™ for Blender 2021.1.4 - 26.0 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to the Blender 3.1.0
  • Upgraded to the 2021.1.4
  • Added "Legacy blend mode" alpha operation and a "Force premultiply opacity" pin to the composite AOV layer node
  • Added the "Use Nodes" in the light property panel
  • Added the Z-Depth values in the Camera Data Node
FIXES SINCE LAST RELEASE
  • Fixed an issue when rendering the curves
  • Bug fixes
You can read about new features of OctaneRender™ 2021.1.4 here:
viewtopic.php?f=24&t=79488
1. OctaneRender™ Server
Windows
Blender Octane Edition - 26.0 (3.1.0)
Octane Server - Enterprise Edition - 26.0
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 26.0 (3.1.0) Linux
Octane Server - Enterprise Edition - 26.0 Linux
azen
Hello all,
As we come closer to our first stable OctaneRender 2021 release, in the meantime we are making available this Test Build for OctaneRender Prime users. We are posting the links here, instead of the Landing Page as we normally would.
It is standard that we only provide Prime Edition plugins for Stable releases - Test Builds are otherwise made available to Studio and Enterprise Edition users. Due to the substantial number of improvements in this Test version, we are going to make an exception and post Prime download links below:
Windows
Blender Octane Edition - 26.0 (3.1.0) Windows
Octane Server - PRIME Edition - 26.0 Windows
Linux
DOWNLOAD
Octane Server - PRIME Edition - 26.0 Linux
As with the Enterprise and Studio users, please be aware that this is still an experimental build, and is not suitable for production work.
