Unable to start render
Adrianna_maj
Have been trying so many times.
Anyone has any ideas?
Started logging on 30.03.22 12:00:22
Octane X Prime PR14 (10000308)
Compute error 2097152:825:
compute device 0: Linking 00696900aaaadec4 shader failed
device 0: failed to initialize render thread 0x7fe164f79bc0
Loaded Octane DLL:Octane X Prime PR14 version:10000308 SDK:PR14
Octane X for Cinema 4D PR14 built for:250 C4D vers:25117
C4D:25117 comp:[MacBook Pro (Adrianna)] OS:[OS X 64 BIT] macOS: Wersja 12.2.1 (kompilacja 21D62) versType:10
CPU:[GenuineIntel, stepping 10, model 14, instruction family 6] speed:2.6 GHz numOfCpu:12Ht
Plugins:[addons advanced_render alembic archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4doctane-R25 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater physx_hybrid projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 89 osl scripts from dir:/Users/adriannamajtczak/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/C4D_OctaneX_Prime_PR14/res/osl_scripts
VRAM used/free/max:0Kb/4Gb/4Gb Out-of-core used:0Kb RAM used:12.478Gb total:16Gb OpenGL free/total:0/0
FumeFx library initialisation error!
--------------------------- EXPORT LOG ---------------------------
Multi-threaded material conversion, thread count=10
Export materials time= 1.359 ms
Collect objects time= 0.102 ms
Mesh creation time = 2.963 ms.
Api update time: 0.056 ms.
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
MB:0/0 ST/MOV:0/0 Nodes:10 Tris:0 DispTris:0 Hairs:0 Meshes:0
Textures Grey8/16:0/0 Rgb32/64:0/0
File not found:/Users/adriannamajtczak/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/updates-ox.txt
>> ProcessUpdate(flags=CMO cAsyn=1 dDelay=1
>> ProcessUpdate end res:0
what type of GPU is installed in your Mac?
Unfortunately old AMD GPUs and Intel GPUs are not supported anymore in new OctaneX PR12/13/14 for macOS 12 Monterey - there were some Apple Metal driver related issues.
If this is your case, you should need to go back to Big Sur 11.6.4, with OctaneX PR11, or you need an AMD Vega, Navi or Big Navi GPU, with macOS 12 Monterey, via Thunderbolt 3 port + eGPU box.
ciao,
Beppe
