I am trying to combine two images with an add node that feeds into a displacement node, but the displacement disappears. Either image works on it's own but not added together.
What's the correct way to do this?
mix images for displacement
I think you are probably using the old "texture displacement," which has a lot of limitations. You'll have better luck using vertex displacement and the Vertex Displacement Mixer node.
