OctaneRender™ for Blender 2021.1.3 - 25.3 [TEST]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to the 2021.1.3
  • Supported to adjust subdivision settings in the viewport rendering
  • Supported to connect currently linked nodes when switching materials
  • Supported to set the default material type
  • Supported to build mesh in Quad(please enable the "OpenSubDiv" in the mesh property panel, the "Subd level" can be 0 if you don't actually need subdivision)
  • Supported the preset for camera imager
  • Added "Object data info" and "Camera info" nodes in the Render AOV and Compositor node trees
  • Adjusted the color of the AOV output node(need to recreate a new one to take effect)
  • Made the render pass UI layout more compact
  • Removed the redundant output nodes
FIXES SINCE LAST RELEASE
  • Fixed the messy mesh issue when vertex displacement is applied
  • Fixed the wrong layout for the unfolded nodes in the property panel
  • Fixed the geometry node instancing issue
  • Fixed an initialization failure on Linux
You can read about new features of OctaneRender™ 2021.1.3 here:
viewtopic.php?f=24&t=79371
1. OctaneRender™ Server
Windows
Blender Octane Edition - 25.3 (3.0.1)
Octane Server - Enterprise Edition - 25.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 25.3 (3.0.1) Linux
Octane Server - Enterprise Edition - 25.3 Linux
azen
Hello all,
As we come closer to our first stable OctaneRender 2021 release, in the meantime we are making available this Test Build for OctaneRender Prime users. We are posting the links here, instead of the Landing Page as we normally would.
It is standard that we only provide Prime Edition plugins for Stable releases - Test Builds are otherwise made available to Studio and Enterprise Edition users. Due to the substantial number of improvements in this Test version, we are going to make an exception and post Prime download links below:
Windows
Blender Octane Edition - 25.3 (3.0.1) Windows
Octane Server - PRIME Edition - 25.3 Windows
Linux
DOWNLOAD
Octane Server - PRIME Edition - 25.3 Linux
As with the Enterprise and Studio users, please be aware that this is still an experimental build, and is not suitable for production work.
