ACES OCIO install HELP!!
I can't get ACES or any OCIO to appear in drop down in render target node. I tried the environment variable option in windows no luck for either Karma or Octane. I've read every post on ACES in the forum. I know how to get ACES in Blender Octane, but can't get it into Houdini I see the option in ROP, but only ACES srgb and from what I read that doesn't affect the IPR view. I can't do anything inside the Render Target node.
Hmm, the OCIO environment variable pointing to the ocio config file should be enough to enable it in Houdini. If you say that your config is not available even for Mantra or Karma, it seems a problem with this variable. Where are you defining it, in the houdini.env file?
