Cryptomatte - consistent seed every new render
KeeWe
I know it was talked about it already some time ago, but is there ANY chances we can get a constant seed when using the material node inside cryptomattes? It's such a pain in the ass to get the mattes if you have to restart renders.
Yes, I know it's not the case with the other nodes, but right now the mattes (instances and particles) only work with this mode.
And if there is no way to change it: could you at least implement a little note inside the AOV manager that it will change? I can't remmeber it between longer jobs...
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
Which AOVS(renderpasses) are you trying and which version? Named nodes should be stable
Return to “User requests”
