Denoiser with batch renderer
lemonade
Hi, I recently tried to use rhino batch render with octane, but the renders weren't denoised. Is there a way to use denoiser with batch render functionality?
Hi
I couldn't reproduce this problem. If I render the named views, the denoised pass was saved. Are you able to provide some more information that might help me investigation the issue? What version of the plugin are you running please?
lemonade
Hi Paul, thanks for your reply.
I found out that I only have this problem with "denoise on completion" option checked, so it's not a problem anymore.
I use 2021.1.2.131 version of the plugin.
lemonade wrote:Hi Paul, thanks for your reply.
Thanks. Even with "Denoise on completion" I could not reproduce this issue. I would be interested to see of other users have had the problem.
Return to “Rhinoceros 3D”
