OctaneRender™ for Blender 2021.1.2 - 25.2 [TEST]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Integrated 2021.1.2
  • Upgraded to Blender 3.0.1
  • Supported to render the hair objects from the curve
  • Supported the geometry nodes instancing
FIXES SINCE LAST RELEASE
  • Fixed the LiveDB crash
  • Fixed an OCIO setup issue
  • Fixed the wrong hair UV issue
  • Fixed the traceback when using OSL textures
  • Fixed an issue when rendering large scenes
  • Fixed the traceback when using Vectron node
  • Fixed the image texture viewport display issue
  • Bug fixes
You can read about new features of OctaneRender™ 2021.1.2 here:
viewtopic.php?f=24&t=79275
1. OctaneRender™ Server
Windows
Blender Octane Edition - 25.2 (3.0.1)
Octane Server - Enterprise Edition - 25.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 25.2 (3.0.1) Linux
Octane Server - Enterprise Edition - 25.2 Linux
azen
Hello all,
After some consideration, we are making available a version of this Test Build for OctaneRender Prime users. We are posting the links here, instead of the Landing Page as we normally would. It is standard that we only provide Prime Edition plugins for Stable releases - Test Builds are otherwise made available to Studio and Enterprise Edition users. Due to the substantial number of improvements in this Test version, we are going to make an exception and post Prime download links below:
Windows
Octane Server - PRIME Edition - 25.2
Linux
DOWNLOAD
Octane Server - PRIME Edition - 25.2 Linux
As with the Enterprise and Studio users, please be aware that this is still an experimental build, and is not suitable for production work.
