Sketchup crashes on save with Octane plugin (demo) enabled
Sub forum for bug reports
ncasedesign
Not sure if this is a bug or intended behavior for the demo version of the plugin, but Sketchup crashes when attempting to save with the Octane plugin installed and enabled in the extension manager. Disabling the plugin and restarting Sketchup allows saving as normal. Using Sketchup 2020 with the OctaneRender demo 2021.1 v1.0.
BK
ncasedesign wrote:Not sure if this is a bug or intended behavior for the demo version of the plugin, but Sketchup crashes when attempting to save with the Octane plugin installed and enabled in the extension manager. Disabling the plugin and restarting Sketchup allows saving as normal. Using Sketchup 2020 with the OctaneRender demo 2021.1 v1.0.
Hi ncasedesign,
Thank you again!!
Yes, this seems expected behavior.
Unfortunately, Octane Demo Plugin does not allow saving files as a limitation.
So we recommend uninstalling or disabling after running the test.
Cheers
Kind Regards
bk3d
Return to “Bug Reports”
