Bellow you can find a screenshot of my layers, Live Picture Viewer and Log notes.
https://imgur.com/a/6f41hP2
https://imgur.com/rjFiZw4
Started logging on 19.01.22 10:37:41
Octane X Enterprise (Mac Pro) (10000307)
could not pick materials, because the geometry has changed and rendering is paused
Compute error 3145728
Compute error 3145728:3282 on device 0:
mesh data upload failed (0).
—————————————————————————————————— Creating zip file:/Users/thetimes/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/_bugreports/octane/bugreport_20220119_103712.zip
Adding file:/Users/thetimes/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/c4doctanelog.txt
Loaded Octane DLL:Octane X Enterprise (Mac Pro) version:10000307 SDK:PR13
Octane X for Cinema 4D PR13 built for:250 C4D vers:25117
C4D:25117 comp:[The’s iMac Pro] OS:[OS X 64 BIT] macOS: Version 12.1 (Build 21C52) versType:10
CPU:[GenuineIntel, stepping 4, model 5, instruction family 6] speed:3 GHz numOfCpu:20Ht
Plugins:[addons advanced_render alembic archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4doctane-R25 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater physx_hybrid projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 89 osl scripts from dir:/Applications/Maxon Cinema 4D R25/plugins/C4D-OctaneX-Enterprise-Pro-PR13 /res/osl_scripts
Deleting texCache folder... /Users/thetimes/Library/OctaneRender/cache/texCache
VRAM used/free/max:0Kb/15.984Gb/15.984Gb Out-of-core used:0Kb RAM used:18.61Gb total:64Gb OpenGL free/total:0/0
File not found:/Users/thetimes/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/updates-ox.txt
FumeFx library initialisation error!
--------------------------- EXPORT LOG ---------------------------
Multi-threaded material conversion, thread count=18
Export materials time= 62.038 ms
Collect objects time= 0.091 ms
Mesh creation time = 0.85 ms.
Api update time: 0.033 ms.
VRAM used/free/max:967Mb/15.04Gb/15.984Gb Out-of-core used:0Kb RAM used:21.28Gb total:64Gb OpenGL free/total:0/0
Export materials time= 61.409 ms
Collect objects time= 3.702 ms
Mesh creation time = 0.815 ms.
Api update time: 0.034 ms.
VRAM used/free/max:966Mb/15.041Gb/15.984Gb Out-of-core used:0Kb RAM used:21.389Gb total:64Gb OpenGL free/total:0/0
Export materials time= 0.607 ms
Collect objects time= 0.036 ms
Mesh creation time = 0.636 ms.
Api update time: 0.037 ms.
VRAM used/free/max:966Mb/15.041Gb/15.984Gb Out-of-core used:0Kb RAM used:21.364Gb total:64Gb OpenGL free/total:0/0
Export materials time= 0.764 ms
Collect objects time= 0.045 ms
Mesh creation time = 0.958 ms.
Api update time: 0.029 ms.
VRAM used/free/max:966Mb/15.041Gb/15.984Gb Out-of-core used:0Kb RAM used:21.291Gb total:64Gb OpenGL free/total:0/0
Export materials time= 1151.073 ms
Collect objects time= 12.616 ms
Mesh creation time = 0.95 ms.
Api update time: 0.035 ms.
VRAM used/free/max:985Mb/15.022Gb/15.984Gb Out-of-core used:0Kb RAM used:21.719Gb total:64Gb OpenGL free/total:0/0
Export materials time= 13581.017 ms
Collect objects time= 15.145 ms
Mesh creation time = 1.116 ms.
Export materials time= 1194.15 ms
Collect objects time= 11.006 ms
Mesh creation time = 0.715 ms.
VRAM used/free/max:985Mb/15.022Gb/15.984Gb Out-of-core used:0Kb RAM used:24.529Gb total:64Gb OpenGL free/total:0/0
Export materials time= 1429.866 ms
Collect objects time= 48.092 ms
Mesh creation time = 1.053 ms.
Api update time: 0.049 ms.
VRAM used/free/max:985Mb/15.022Gb/15.984Gb Out-of-core used:0Kb RAM used:22.191Gb total:64Gb OpenGL free/total:0/0
Export materials time= 2111.707 ms
Collect objects time= 0.257 ms
Mesh creation time = 128.941 ms.
Api update time: 0.036 ms.
VRAM used/free/max:1.309Gb/14.676Gb/15.984Gb Out-of-core used:0Kb RAM used:26.193Gb total:64Gb OpenGL free/total:0/0
Export materials time= 1728.511 ms
Collect objects time= 14.247 ms
Mesh creation time = 99.375 ms.
VRAM used/free/max:1.309Gb/14.676Gb/15.984Gb Out-of-core used:0Kb RAM used:28.103Gb total:64Gb OpenGL free/total:0/0
FRAME:1 fps:30
Export materials time= 2769.567 ms
Collect objects time= 0.285 ms
Mesh creation time = 379.614 ms.
MB:0/0 ST/MOV:0/7 Nodes:40 Tris:4.671m DispTris:12 Hairs:0 Meshes:13
Textures Grey8/16:0/0 Rgb32/64:3/0
VRAM used/free/max:6.331Gb/9.653Gb/15.984Gb Out-of-core used:0Kb RAM used:30.595Gb total:64Gb OpenGL free/total:0/0
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Check geometry subdivisons.
Picture viewer uses 'Render' subdivisions. But Live Viewer uses 'Editor' subdivision values.
Try to decrease 'render/editor' subdivison values.
Break rendering...
**** RENDER FINISHED **** stat=6
reset failure...
FRAME:1 fps:30
Export materials time= 1729.34 ms
Collect objects time= 0.301 ms
Mesh creation time = 326.816 ms.
VRAM used/free/max:2.713Gb/13.272Gb/15.984Gb Out-of-core used:0Kb RAM used:31.785Gb total:64Gb OpenGL free/total:0/0
Break rendering...
Export materials time= 1780.692 ms
Collect objects time= 0.246 ms
Mesh creation time = 89.607 ms.
VRAM used/free/max:2.242Gb/13.742Gb/15.984Gb Out-of-core used:0Kb RAM used:29.765Gb total:64Gb OpenGL free/total:0/0
FRAME:1 fps:30
Export materials time= 1798.9 ms
Collect objects time= 0.296 ms
Mesh creation time = 395.965 ms.
VRAM used/free/max:2.713Gb/13.272Gb/15.984Gb Out-of-core used:0Kb RAM used:31.416Gb total:64Gb OpenGL free/total:0/0
mblurTM=0sec. createTM=0sec. updateTM=0sec. renderTM:4.279sec. totalTM:9.115sec.
Export materials time= 2762.472 ms
Collect objects time= 50.811 ms
Mesh creation time = 96.362 ms.
VRAM used/free/max:2.713Gb/13.272Gb/15.984Gb Out-of-core used:0Kb RAM used:30.684Gb total:64Gb OpenGL free/total:0/0
FRAME:30 fps:30
Export materials time= 1882.672 ms
Collect objects time= 0.306 ms
Mesh creation time = 427.877 ms.
VRAM used/free/max:2.713Gb/13.272Gb/15.984Gb Out-of-core used:0Kb RAM used:31.558Gb total:64Gb OpenGL free/total:0/0
Break rendering...
**** RENDER FINISHED **** stat=3
reset failure...
FRAME:30 fps:30
Export materials time= 1918.951 ms
Collect objects time= 0.287 ms
Mesh creation time = 321.467 ms.
VRAM used/free/max:2.713Gb/13.271Gb/15.984Gb Out-of-core used:0Kb RAM used:33.408Gb total:64Gb OpenGL free/total:0/0
Break rendering...
reset failure...
FRAME:30 fps:30
Export materials time= 1940.182 ms
Mesh creation time = 327.417 ms.
VRAM used/free/max:2.713Gb/13.271Gb/15.984Gb Out-of-core used:0Kb RAM used:34.443Gb total:64Gb OpenGL free/total:0/0
Break rendering...
reset failure...
FRAME:30 fps:30
Export materials time= 2062.769 ms
Collect objects time= 0.281 ms
Mesh creation time = 327.636 ms.
VRAM used/free/max:2.713Gb/13.271Gb/15.984Gb Out-of-core used:0Kb RAM used:36.246Gb total:64Gb OpenGL free/total:0/0
Break rendering...
**** RENDER FINISHED **** stat=6 ————————————————————————————————————
Traceback (most recent call last):
File "scriptmanager", line 3, in <module>
ModuleNotFoundError:No module named 'urllib2'
